Spec Stage 3??
Old Sep 23, 2008 | 12:44 PM
slomarao's Avatar
Spec Stage 3??
Wondering how they are these days? I know they have came out with new models that are better and better but that doesnt say much.
So i you have one please speak out? Thinking i will order one by the weekend. Thanx guys.
Old Sep 24, 2008 | 04:40 PM
slomarao's Avatar
anyone?
Old Sep 24, 2008 | 05:01 PM
Mtxz453's Avatar
its a pain in the neck and a total different world from the stock one. It doesn't ease into gear it kind of just slams and catches. If you let the clutch out slow and give it a little gas it will chatter and almost die. So to me the drivability of this thing isnt that great, but once you get used to it, its not horrible. If I could do it again I would probably try the stage 2+ because traffic is a nightmare. Most of the time to get into first i let it out a little fast to avoid chatter and chirp the tires.
Old Sep 24, 2008 | 07:48 PM
mzgp5x's Avatar
I have a Spec 3 with an Alum flywheel. App... 97ss 383 D1. They tend to chatter a bit when new. Yhey can chatter alot in reverse gear. After some run in, they do not chatter (@ least mine does not). I don't slip it much. Let it out agressive. This is the second Spec clutch I have used. I wore out a previous Spec disc. Replaced it with a Spec 3.
Old Sep 24, 2008 | 09:50 PM
slomarao's Avatar
Well i put down the numbers in the sig, planning on finishing up with a few more odds and ends, hopefully with 335-340rwhp. Than im going to hit it with a 150 so i am going to need something quite strong.
You guys think i could get away with the Mcloed single disk? Im not Street twin territory yet but their weaker clutch has caught my eye
any thoughts on it?
Old Sep 25, 2008 | 03:53 PM
ramair96ws6's Avatar
do it once, do it right, get a street twin. no other clutch comes close for a LT1 car.
Old Sep 25, 2008 | 04:23 PM
slomarao's Avatar
my twig 10 bolt wont like th ST too much. Plus i drive this car a lot. Dont wana deal with that $hit.
Old Sep 25, 2008 | 06:16 PM
if you launch on any clutch that twig will break. I'd rather have an excellent clutch thet doesn't chatter, shimmy, break (specs are junk btw) then a band aid. JMHO trust me I have been through some clutches., power breaks everything hahah
Old Sep 28, 2008 | 12:52 PM
slomarao's Avatar
anyone else?
Old Sep 28, 2008 | 03:08 PM
matLT1's Avatar
I have the spec stage 3 currently. It is a very grabby, but once you understand how to operate the clutch pedal chatter will rarely occur. The spec 3 does not like to be slipped (it is afterall a six puck clutch). I have found good results by slipping the clutch from ~1500 rpm and quickly releasing the clutch pedal. Too low of an rpm and the car lunges forward and too high the clutch will slip too much and begin to chatter. I also have the SPEC steel flywheel. I have not heard good results from people using a Cast Iron flywheel with an abrasive clutch.
Old Sep 30, 2008 | 08:38 AM
slomarao's Avatar
ttt
Old Oct 2, 2008 | 04:55 PM
chevyrules85's Avatar
anyone else? im also looking into this clutch and just wanted some feedback from some others who have actually used it
Old Oct 2, 2008 | 07:25 PM
billymz28's Avatar
I loved my spec stg 3. It was a little bit of a pain when i first got it but got used to it and started to like it. It is a stage 3 clutch it is designed to grab and be raced so of course it isnt the best for stop and go traffic. When i got the clutch i knew what i was in for so that is why i bought it. I wanted a clutch that grab and didnt slip.
Old Oct 2, 2008 | 09:23 PM
you say its not to good in daily traffic, not to good but is it liveable? mines gonna be a DD but taken to the track maybe once a weekend, after you get used to it is it ok in traffic?
Old Oct 2, 2008 | 09:24 PM
matLT1's Avatar
Originally Posted by slomarao
ttt
Is your sig. up to date? If so, why do you feel the need for a clutch rated at over 700 ft-lbs? You could easily get by on the Stage 2 looking at your sig. The Stage 2 is more streetable, much less likely to chatter, and will have a longer life.
