Spec 3 Install Question
Old Oct 1, 2004 | 09:30 PM
95RagtopTA's Avatar
I'm installing a Spec 3 clutch and was wondering if the pressure plate needs to be aligned to the flywheel in any certain way. I've read that the flywheel should have a white X on it that should match up with a "dot" on the pressure plate. I see neither. Could this be a problem? Also, I resurfaced my flywheel but did not have it balanced. Figured that the amount taken off would not justify having it balanced. Am I wrong to assume this??
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
nophix
Nov 30, 2014 10:26 PM
wytblur
Mar 2, 2003 03:40 PM
Chrisdude
Jul 24, 2002 02:25 PM
