Spec 2+ with stock flywheel?
Old Aug 27, 2007 | 12:24 AM
92_RSCamaro's Avatar
Is anyone running a Spec 2+ with a stock flywheel or would anyone not recommend it? If you would not run a stock flywheel then what one would you suggest?
Old Aug 27, 2007 | 02:16 AM
96LT1TX's Avatar
I have a stage 2 kevlar SPEC clutch, and I love it. Havent tried any hard launches yet though with the slicks, and I am at high altitude so power loads on the transmission are a litttle different.
Old Aug 27, 2007 | 10:45 AM
BlackbirdWS6's Avatar
I run a spec stage 3 on my stock flywheel. It was resurfaced by the place that installed it. Works just fine but if you wanted something new and different...go with the spec flywheel they recommends for that clutch.
-Brian
Old Aug 27, 2007 | 10:52 AM
dangalla's Avatar
just a tidbit of info..
the ram is roughly the same price as the spec steel only its aluminum with a steel insert
oh yeah and i pretty much read nothing but bad things about spec, but i dont own one myself, if i were you i would get a lt4 pressure plate and a mcleod single race disc, which is considerably cheaper
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
