SPEC 2 clutch chatter, no 6th gear, other problems
Old Jul 20, 2004 | 11:55 PM
joebeemish's Avatar
I just had my engine rebuilt and I added a aluminum flywheel and SPEC Stage 2 clutch. I need to rev the engine high (2-3K RPM) to get it to start in 1st gear smoothly, and even that is iffy. Shifting is very rough (chatter) if I am not pushing hard on the throttle and shifting at high RPM (at least 2.5K) Downshifting can be really rough - sometimes ALOT of chatter. On the highway, at 70 MPH, if I put it in 6th gear an try to accelerate or decelerate, the transmission sounds like it is going to buck out of the car. I have not been able to use 6th gear.
Thanks in advance.
Old Jul 21, 2004 | 05:55 PM
Janny's Avatar
Re: SPEC 2 clutch chatter, no 6th gear, other problems
Mine is chattery as well. It grabs like no tomorrow, but it chatters even after 5K miles unless I rev it high when first starting out. As for 6'th gear, I have 3.73 gears so I don't have any issues; you may want ot consider a gear change if you have anything less.
Old Jul 21, 2004 | 06:45 PM
joebeemish's Avatar
Does it chatter on downshifts? Does it chatter if the RPM goes below 2000 and you accelerate in any gear?
Aside - I notice you mention LT1 edit - what do you think?
Old Jul 22, 2004 | 05:12 PM
TransAm396's Avatar
what exactly is chattering and whats it sound like?
Old Jul 22, 2004 | 05:41 PM
Janny's Avatar
Mine will make a bit of chatter on a downshift if I mess up the shift, but not regularly. Any RPM below 2000 and the car lurches a bunch, and yes it does feel like the tranny is bucking. This I attribute to cam surge. The engine likes to be loaded, then everything feels smooth. I used LT1 Edit to run a bit more timing from 800 to 3000 and this helped smooth things out a bit. I also set the idle speed up a bit. All in all the car definitely feels like a bit of a wild animal, but that is what sports cars are about, so I'm OK with it. I sure wouldn't want it a whole lot rougher though.
ChrisFrez
Feb 15, 2015 07:49 AM
HectorM52
Jan 30, 2015 11:08 PM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Dec 21, 2014 09:47 PM
Jul 4, 2005 05:00 PM
