SPEC 2 clutch chatter, no 6th gear, other problems
I just had my engine rebuilt and I added a aluminum flywheel and SPEC Stage 2 clutch. I need to rev the engine high (2-3K RPM) to get it to start in 1st gear smoothly, and even that is iffy. Shifting is very rough (chatter) if I am not pushing hard on the throttle and shifting at high RPM (at least 2.5K) Downshifting can be really rough - sometimes ALOT of chatter. On the highway, at 70 MPH, if I put it in 6th gear an try to accelerate or decelerate, the transmission sounds like it is going to buck out of the car. I have not been able to use 6th gear.
Thanks in advance.
Thanks in advance.
Re: SPEC 2 clutch chatter, no 6th gear, other problems
Mine is chattery as well. It grabs like no tomorrow, but it chatters even after 5K miles unless I rev it high when first starting out. As for 6'th gear, I have 3.73 gears so I don't have any issues; you may want ot consider a gear change if you have anything less.
Does it chatter on downshifts? Does it chatter if the RPM goes below 2000 and you accelerate in any gear?
Aside - I notice you mention LT1 edit - what do you think?
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Dec 21, 2014 09:47 PM
Jul 4, 2005 05:00 PM
