something in rear leaking
i have a question. i got as far under my z as i could without a jack, to look at my exhaust, and noticed something depositied on my floor. looked up and the rear axle had something on it. i looked as best i could and noticed it was comming from above. i plan to jack the car up tomorrow and check it out. any ideas befor i get into it? the reason why i was looking at my exhaust is because i am replacing my stock with the catback slp lm. anyhow it is a 94 z. any help would be appreciated, i am not exactly a wrench. i havent really looked to hard but anyone know what gears were put in these?
Re: something in rear leaking
Originally Posted by johnnyb
are they worth changing or just forget about it?
.. its only gonna get worse
ok well i got er jacked up and ready to install my exhaust when i get it tomorrow. anyhow i got a chance to look at the leak in the rear. i noticed that the leak was actually comming from the drain plug. also i noticed that where the two axles have some build up on them, where they come out from the pumpkin??, but nothing bad. i will probably remove the drain plug and add some tefflon. and replace. everything else looks good.
ChrisFrez
Feb 22, 2015 08:47 AM
