Slave cylinder install help
Old Sep 14, 2003 | 07:36 AM
1 Hot Z's Avatar
I am in the process of putting in a new GM master/slave cylinder unit I have one question. There is a white plastic strap attached to the slave cyinder I am not sure if I am to cut it off or is it suppose to stay on there for some reason. Any help would be appreciated.
Thanks, Scott
Old Sep 14, 2003 | 10:05 AM
LPEdave's Avatar
You cut the straps off, and leave the little cap on the end of the piston...
Dave
Old Sep 15, 2003 | 07:03 AM
PatriotTA's Avatar
You don't have to cut those straps. They are on there for an easy 1st install. If you don't cut them off, its easier to install the slave cylinder, and the first time you step on the clutch pedal (after everything's installed), those straps will break. That's how they are put in from the factory (with the straps intact). If you already cut them off, no big deal, its just a little harder to install. Also, use some grease on the plastic cap of the piston, where it goes into that dimple in the clutch fork.
Nov 18, 2023 07:21 PM
HectorM52
Jul 30, 2017 11:46 AM
Ringmaster72
Mar 19, 2015 03:32 PM
Briah.hood
Feb 17, 2015 02:10 PM
Jason Short
Jan 19, 2015 06:34 PM
