Pinion depth question
Old Sep 10, 2003 | 07:31 AM
95Blackhawk's Avatar
My old pinion was with a 3.73 and had a depth of 2.313 as marked on the gear itself. Now I am putting in 4.10's and my depth is marked as 2.282. This is pretty significant isn't it?
As many others have stated, my plan was to just reuse the old shims and check my contact pattern since I don't have a depth gauge. However, this to me is a big difference of 0.031 inches. Shoudn't I compensate for it?
Thanks all,
Ben
Old Sep 10, 2003 | 10:38 PM
V-2 SQ Jes's Avatar
that difference may just be the difference in the way the new gear was made. i would start with the old shim and try it.
Old Sep 13, 2003 | 09:56 AM
FIREHAWK_21's Avatar
You can get a pinion setting tool at summitracing.com.
PRO-66516 Pinion gear depth setting tool $99.95
Old Sep 15, 2003 | 08:39 AM
96WS6TA's Avatar
It has been my experience that the pinion depth marked on the gear is a good STARTING point, but may not give you the best pattern. If your old gears had a good pattern and were quiet, I would re-use your old shim. I have a pinion depth tool and it is only marginally usefull.
Victor Lamb
Aug 26, 2017 02:52 PM
oldschool
Feb 9, 2016 09:21 PM
Jun 6, 2015 08:27 AM
kev93z28
Aug 19, 2002 12:48 AM
