Slack/Noise in Drivetrain
Old Apr 3, 2006 | 02:46 PM
EKO's Avatar
EKO
Whenever I put any kind of torque to the wheels, I get this speed (not RPM) dependent grinding/popping noise. I jacked the car up and rotated the driveshaft back and forth and noticed I have about 1/4 turn of slack before one of the wheels turns. As I rock the driveshaft back and forth, the rear makes a clunk as it catches and the wheel turns. Any thoughts on what the issue is?
Old Apr 3, 2006 | 05:07 PM
94Camaro_Z_28's Avatar
Re: Slack/Noise in Drivetrain
1/4 turn seems like a lot. All I can think is broken teeth on the pinion gear.
Old Apr 3, 2006 | 07:32 PM
EKO's Avatar
EKO
I thought so too, but it does it independent of position. That would mean that every other tooth was broken. Do you think that slack would cause the noise under high torque?
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
WobblySausage
Oct 7, 2015 02:44 PM
War Engine
Aug 21, 2015 05:28 AM
alphaauto
Jul 26, 2015 04:40 PM
