should I switch to a 2,800 stall?
Old Sep 8, 2003 | 08:09 PM
  #16
funina91ss's Avatar
Originally posted by viperkiller
used to have 2500 stall
since thelast time i was here i went to a 3500
had teh rev limit prod again. i changed teh shift points to right under rev limit. i shift pretty quick but it works well becouse i keep the rpm in peak hp range.
What year is your car?
I just put in the obd2 pcm today and it fell's alot stronger(had it tuned to the cam) Should have my plug wires Thursday and take it to the track on Fiday.. Wish me luck I will see how it does..
Old Sep 9, 2003 | 12:40 AM
  #17
94 TA TT2S's Avatar
funina91ss
Hey What all did you have to do to swap over...??? I may be doing the same as you.....LMK how it goes when you run....Thanks Ben
Old Sep 9, 2003 | 05:44 AM
  #18
funina91ss's Avatar
All you have to do is go to MadZ28.com Ion will set you up with the pcm ready to go and you also have to change the Knock Sensor to a OBD2 sensor.
Old Sep 10, 2003 | 08:48 AM
  #19
97Z-M6's Avatar
last night brad (viperkiller) came over and we did some tuning on his car and we seem to have the obd1 problem fix (3500 stall makes it tough). but i think it would be wise to wait a week and do so trial and error test. to make sure. but no problems as of yet.
the obd2 swap will fix it and ion is a great.
Old Sep 10, 2003 | 11:02 AM
  #20
dougg01's Avatar
I had the WOT shifting problem with a stall for a long time (only a 2400 SLP at first) and so did a friend of mine. I went through a couple different programmers and it never was right (obvious rev limiter action between shifts or no shift at all). After many tries and getting a new, bigger stall (yank 3200) I went to Brian at PCMforless. He fixed me up with a basic program and it shifted. Of course the program, being e-mail-order, needed some adjustments, but it go me going. He did the same for my friend, but we needed to do more tweaks to his for some reason to get things just right. I'm still learning, but OBDI and the stall/no shift thing is something that the do-it-yourselfer can indeed overcome.
Good luck. Owingsville, right....? They're closed this week.....Finals in Indy. Next Friday I'm hoping to go myself.
Old Sep 10, 2003 | 04:26 PM
  #21
funina91ss's Avatar
Thanks for the headsup I didnt know that..I will see how it does at KV I guss. traction !
Old Sep 10, 2003 | 10:44 PM
  #22
OneFlyn95z28's Avatar
Well Ed's fix has been verified in on a 10.61 second pass with a 1.37 60ft running a 4,000+ stall
Maybe you should try having him tune your car again LOL
Old Sep 10, 2003 | 10:53 PM
  #23
funina91ss's Avatar
If he didnt lock his pcm or charge so much I might think about it. But I have had the "trans program" mod.. It doesnt work for all cars... will be continued....
Old Sep 12, 2003 | 05:14 AM
  #24
S.J.S.'s Avatar
Okay 2 things.......
Now I'm actually worried. Why is it that here everyone is saying to go to the OBDII when I just ordered the conversion to the OBD1 from PCM. Brian told me that it would be the best for my car.
Second 383Z4ME.....I got almost the exact same setup as you and the trans shop just custom made me a torque converter to my specs. He put in a 2400 stall and also told me that it would be best for my daily driver. But you had problems with it. My motor is almost done and I feel like I'm back at square one.
Second guessing myself again.
Old Sep 13, 2003 | 12:25 AM
  #25
funina91ss's Avatar
YES YES YES it works The car shifted great ran a 7.90 on real street tires Not drag radials. well what it did was run better on street tires than my et streets
best NA street tire run was 1.74 7.90
best NA Slick Tire run was 1.77 7.97
This was the best night I have had at the track for a long time even thougth I didnt get to spray it. I am just glad it goes threw the gears now.. I really Have to Thank Ion Salton (MadZ28.com) Now lets get this thing tuned and have some fun
Old Sep 13, 2003 | 02:04 AM
  #26
91SS
This fix is only a few monthes(at best) old. Ed tested it on a 10 second car till it worked and this fix has worked on every car since. That is unless you mess with the MPH tables under WOT
Any fix out there is a copy of this fix.
Cam's maro
Aug 11, 2015 07:45 AM
jackpawt883
Jul 31, 2015 08:15 AM
detroitmuscle
Jul 31, 2015 04:21 AM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
