Should I resurface my flywheel in this case?
Old May 7, 2005 | 03:51 PM
madwolf's Avatar
I got a used Spec Stage 3 clutch disk and pressure plate. The clutch also came with the matching flywheel from the same car.
Now I have an aluminum flywheel that is smooth, but has some spotting on it (also used for a little while). I plan on using this flywheel instead of the stock one. Since the clutch is not new, should I get the aluminum flywheel resurfaced? How about pressure plate? Can I/should I resurface it?
The transmission and hydraulics will be new.
Thanks.
Old May 9, 2005 | 04:11 AM
GreenDemon's Avatar
Re: Should I resurface my flywheel in this case?
The safe thing to do would be to take it in and get it resurfaced. I don't know though, I'd bolt it up to the crank and measure for warpage, and if it was acceptable I'd just run it over with some 400 grit (preferrably with a circular sander) to remove any glazing that might have occurred. You could rough up the pressure plate too a little just to be safe but don't get carried away. I don't think any pressure plates are resurfacable, at least for standard auto apps, it's a wear item along with the clutch disk.
Formula Steve
Sep 19, 2023 08:31 AM
Bxlt1
Sep 29, 2015 03:18 PM
karpetcm
Sep 29, 2015 10:08 AM
Bxlt1
Sep 17, 2015 08:31 AM
