short throw shifter
Old Jan 31, 2006 | 08:04 PM
deputydough's Avatar
short throw shifter
ok, i'm a little confused. if you buy a short throw shifter, do you put your old shift rod back on or what? the ws6 store sells a short shifter(just the rod) and the slp and 5.0 shifters. i don't really want the "stick" to be lower i just want quicker shifts. thanks
Old Jan 31, 2006 | 10:09 PM
OBE1 95Z28's Avatar
Re: short throw shifter
Shifters usually come with new rods, but not the **** (you transfer your **** to the new shifter). Some guys like the shifting rod short. Lou's Short Stick is a common rod that can replace the rod that comes with the shifter. The Pro 5 rod has a long threaded portion that can be cut back to shorten that rod.
The stock rod is "part of the problem" as it has a rubber isolator near the bottom of the rod that gives the shifter a mushy feeling.
Old Feb 1, 2006 | 05:33 AM
Z28_95RIDE's Avatar
Short throw = a shorter (lower) stick. Quicker shifts are 1. up to your technique and 2. a more precise shifter. OBE1 95Z28 is telling you something about the reason for imprecise shifts from the factory shifter. The isolastic stick sacrifices precision shifting in order to eliminate vibration and buzzing coming up from the drive train. If you go with an aftermarket shifter, you will have more precise shifts but may (as I have) experience slight or moderate buzzing coming up through the transmission into the car's interior.
BTW, a shorter stick will give you quicker shifts because you will move the stick a shorter distance. It is a fulcrum principle. A short lever means that you move the opposite end more quickly with proportionately more effort.
nikolt1
Feb 27, 2015 09:10 PM
94z28jbw
Sep 8, 2002 03:22 PM
CeeBee94Z
Jul 31, 2002 02:20 PM
ferraricameron
Jul 29, 2002 07:46 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
