Shimming a resurfaced flywheel
Old May 5, 2005 | 11:50 PM
blackz97's Avatar
Picked up my flywheel from the machine shop today. I asked the machinist about shimming the flywheel, he said it wasnt neccessary because they take less then .010 off the surface... Is this true or should i be looking for shims myself, and a new machinist?
Steve
Old May 6, 2005 | 12:46 AM
MachinistOne's Avatar
Re: Shimming a resurfaced flywheel
Some flywheels have a minimum thickness spec, just like OHC cylinder heads. So yes, flywheels can be re-surfaced too much, if all they removed was .010" then you have plenty of material left. Flywheel shims are avalible in thicknesses of .025" and .050".
Old May 6, 2005 | 01:06 AM
madwolf's Avatar
Sorry to use this thread, but do you know what is the stock thickness for an LT1 flywheel? I have an aluminum one that has been resurfaced and I might need to do it once again. I'd like to know if I can reuse it.
Thanks.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
