Shim 10 bolt carrier very hard???
Old Mar 2, 2010 | 10:12 PM
fastlt1camaro's Avatar
Is it really hard to shim a 10 bolt carrier correctly? Its out of a 94 z28 thanks.
Old Mar 3, 2010 | 07:13 AM
AL SS590 M6's Avatar
Moderator
Shimming the carrier is easy. You just move shims from side to side 'till the lash is right after you've got the preload right.
Shimming the pinion to get the gear pattern right is the hard part and the reason that I have a pro do my gears.
So if you are just changing the carrier and using the same gears without moving the pinion, go for it.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
thenewkid
Nov 18, 2014 12:57 PM
