Shifting Noise 00 WS6
whats a good skip shift eliminator? thats cheaper? sorry to sound broke but i am. first car payment lol. But just got paided but only bi weekly so. I just want to have fun with it but cause no problems to anything.. so if a pro 5.0 shifter good and safe from missing a shift? thanks.
because i hate (the skip shift). it like misses with your head when it randomly kicks on. i dont know about everyone but when i am exiting a turn i am not giving much gas and i am trying to put it in 2nd and it just slows ya down having to wait for the gears to open up. thats like from a red light turn or stop sign you know? thanks i really want to get rid of it.
Shifting problems?
Check your fluid level and color. If it's dark/black, change it by sucking it out of the cylinder with a bulb syringe and adding more. Drive it around a couple blocks and change it again.
Also it is hard somtimes to get it into reverse feels like it is stuck. is it bad shifting the shifter in the gears hard? it seems like it takes good effort to shift. is that common? so a short shifter would make it harder to shift because it is less leverage?
Mike
the fluid huh? well i hope it doesnt need any clutch! it has 55,500miles on it. it just seems like sometimes it is hard to put it in a gear. reverse feels alittle funny i dont know if its because its used the least of all the gears but it doesnt feel the same as putting it in 1st. even 1st sometimes feels like it has one click into the gear and then two hard to explain. i dont know if it gets caught on something small for a second but i just notice it sometimes. never had a Manual Car before this you know but i think it should be ok.
Suck it out with a bulb syringe, stick more fluid in, drive, repeat as necessary.
My cousin's GTO was acting stupid while shifting it...he changed the fluid and has no more problems... Happens pretty often with a hydraulic clutch, especially on LS1/LS2s for some reason.
Mike
If the problem is between just a couple of gears, then it could be a syncro problem or bent shifter rail.
Just a comment on the pilot bearing/bushing.....as I understand it....the bearing is worse for coming apart than the bushing. I've seen many pilot bearings give up the ghost compared the bushing. When I upgraded my clutch to an SLP unit, I didn't go with the bearing....I put a new bushing in it.
techstar
Aug 6, 2015 11:20 AM
