shifting issue
Old Apr 9, 2009 | 05:01 PM
red94chicken's Avatar
shifting issue
in my 94 ta when getting into it and making wot 1-2 and 2-3 shift car wont shift until you let out? haven't tried a wot 3-4 shift for obvious reasons. any ideas
Old Apr 9, 2009 | 05:14 PM
Sunsetmaro's Avatar
hey
I had the same problem with my tranny before my first rebuild... WOT it wouldnt shift untill you stomped the pedal again...About a month later, 3rd and 4th gear went.... 1400.00 later and 2 years my tranny is acting up again =\...little scared and wanting to convert to a 6-speed now
Old Apr 9, 2009 | 06:01 PM
Performabuilt's Avatar
Supporting Vendor
Any mods to the car power adders/ cam/ gears?
Actually we get alotta guys switching back the other way, Seems 1000 dollar clutch sets a couple times a year get old too.
Old Apr 9, 2009 | 06:12 PM
well ha. its got heads cam and gears but no tune.. been fine for the last 3 months cause i can't find anyone to tune it.. nor can i afford it but regardless it hadn't had a problem till two weeks ago. normal driving is fine which i normally do and out of the blue i ran out first and it did that.. so then i tried second, same thing..
Old Apr 9, 2009 | 06:14 PM
lt4 heads xfi 280 cam 2300 stall lt's and 3.23's. had 2.73s stock.
Old Apr 9, 2009 | 08:19 PM
Supporting Vendor
Well still could be tuning but you can do serios damage with mods and gear changes without the proper tune , presures, shift points . lockup everything will be outta wack.
Old Apr 9, 2009 | 09:23 PM
everything works just as it should... before the heads and cam had the stall and the wrong gear ratio for about a year without a problem. and i have put a ****load of miles on it with it driving exactly the same as it always has.. lockup works normal. shifts normal. i could launch the car as hard as it can launch and no problems, wot downshift no problems.... use to blow the tires over on the shift, never hit the limiter. i really rely on this car so i normally just putt it around also because of the lack of tune i dont rev it out. had raced someone the weekend before it started acting up and all was fine, was late for work and hopped on it and in 1st got to 5200ish and it shot straight to the limiter. let out it shifted.. did again to confirm. then tried second basically the same thing.. stopped at a tranny shop and they checked the fluid and said tht it was fine and didn't seem any signs of concern from the oil. went for a test drive and the guy said he was going ot discuss it with the other trans guy to see if they could narrow it down...hot holding my breathe on that answer..
PCLZ28
Dec 24, 2015 05:19 PM
Apr 16, 2015 09:57 AM
BigWil
Mar 29, 2015 12:24 PM
jackpawt883
Feb 26, 2015 09:04 PM
armedtrigger
Feb 24, 2015 08:30 PM
