shift solieniod
Old Jun 24, 2008 | 10:16 PM
mikemassi's Avatar
shift solieniod
i have a 94 z28 automatic with 93,000 miles. recently my car started acting up and when i first start the car everything seems alright, but the car gets stuck in first til i hit revv limiter, then it goes into second and when it does the service engine soon light comes on. then once its in second the car wont go back to first and it launches foms second gear, once i turn the cr off, it starts all over and the light is off untill i get it to go into second. think it could be a shifter soliniod?
Old Jun 25, 2008 | 12:39 AM
WS6T3RROR's Avatar
Sounds like it to me, or a valve stuck in the valve body. You should be able to manually shift down to first and up to second until you can get around to fixing it. The manual valve should bleed pressure off if you go down to 1 and then up to 2. Change em both when you get in there, they're cheap. I think your bad one will be on the drivers side.
Only other thing I can really think of that would do that is either a stuck checkball in the seperator plate or an internal mechanical failure. Try the noids first. Change the filter while you're in there.
Old Jun 25, 2008 | 06:06 PM
We have a "Drivetrain" forum for questions like this. I'll move it there for you.
Old Jun 25, 2008 | 06:15 PM
Performabuilt's Avatar
Supporting Vendor
You are setting limp mode have the car scanned and get the codes and the answer will be there
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
