shift light in side defrost hole?
Old Jan 17, 2007 | 11:38 PM
flolo's Avatar
has anyone installed there shift light in the side defrost hole in the a-pillar? I just got my raptor, and think it would be pretty cool ta do. If so, any tips or suggestions on how to mount it?
Old Feb 1, 2007 | 01:17 AM
FifeDogg's Avatar
bump. I am curious about this also. If installed in the defrost hole, would I still be able to use the rubber cap to block out the light at night? Also how hard is it to take off the A-piller to install the light.
Old Feb 1, 2007 | 01:44 AM
SnakeStomper's Avatar
that's exactly where I mounted mine. the pillar comes off fairly easy. I routed the wire under the dash and tapped into the power from the radio. i cut the little vents off of the little plastic ring with a dremel and put some electrical tape around the shiflight to provide a tight fit. if i need to change my settings, all i do is pull out the plastic ring, pull out the raptor and reprogram it.
Jlo
Feb 3, 2015 09:41 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
