Setting Up Gears for the Third Time - Please Help....
Old Nov 4, 2004 | 06:24 AM
  #16
Jon97Z's Avatar
Re: Setting Up Gears for the Third Time - Please Help....
Originally Posted by roguedriver
What about the whine? That still happen in neutral or that go away too?
The whine goes away in neutral along with the rubbing/grinding noise.
Old Nov 4, 2004 | 06:54 AM
  #17
Capn Pete's Avatar
Since all the noise goes away when you're in neutral means that all the noise comes from the "power" side of the gears when they're actually under load. If you're coasting along in neutral, the axles are driving the driveshaft (instead of the driveshaft driving the axles), so the gears are riding on the opposite side of the teeth than normal. All this does is verify that there's a gear problem IMO. "Proper" setup may or may not help.
Old Nov 4, 2004 | 09:01 AM
  #18
Jon97Z's Avatar
So, there's no chance it could be the driveshaft?
Old Nov 4, 2004 | 11:03 AM
  #19
Capn Pete's Avatar
I don't understand what you think the driveshaft is doing to make that noise? Hitting something?! How does a driveshaft make an intermittent "grinding noise"?! It's either always rubbing/hitting something, or never hitting anything. I mean, I suppose maybe a U-joint could be getting tight and binding up as you slow down, but I really doubt that, as I'm sure there would be a heck of a vibration in the car always if a U-joint was going bad. Gear noise is gear noise; JMO:blah:.
Old Nov 5, 2004 | 12:14 PM
  #20
Jon97Z's Avatar
I certainly do appreciate everyone's replies to this matter. Thanks guys!
I'll just pull the diff again see if I can find something I missed.
HectorM52
Jul 30, 2017 11:46 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Noenav
Dec 6, 2014 07:35 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
