Servo Cover Snap Ring Help!!!!!
Old Aug 28, 2004 | 01:27 PM
AppleSauce4379's Avatar
Ok I just got done installing my shift kit and now I can't get the snap ring to go back on the servo cover. I pried the cover all the way in and got the ends started but i can't get the top to snap in. I tired lowering the trans and it didn't do me any good. Does anyone have any adivce on how to get this stupid ring back in? Thanks
Old Sep 20, 2004 | 08:54 AM
jeremyferguson's Avatar
Re: Servo Cover Snap Ring Help!!!!!
All I can say is I feel your pain. I don't know of any quick tips that will make it easier besides maybe two sets of hands. Have someone else pry in on the cover and you can use both of your hands to try to get the ring back in the groove. I just did the 'ole transgo last week. I'm sure glad I don't have to do that again anytime soon!
Old Sep 21, 2004 | 02:18 AM
Pro Built Automatics's Avatar
Which shift kit did you install? If you are using the Trans-Go, then go back to the instructions & you will find that you added to many spacers to the apply servo, to take up the band clearance. You should have about .050 - .060 clearance.
Old Sep 21, 2004 | 06:02 AM
Very true, but I still had trouble using only one spacer simply because of the lack of space between the servo(cover) and the side of the transmission tunnel, as I installed the Trans Go with the trans in the car.
I did manage to get it all back together with both spacers in there, then when I checked the clearance through the slot in the bottom of the case, I found that it was in fact too tight and had to take one of the spacers out and put the servo back together. Quite a PITA!
Old Sep 21, 2004 | 07:20 AM
That is what I thought might have happen. Have seen this before.
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
19redta96
Jul 20, 2002 02:09 PM
