Serious grinding from where??
Old Nov 17, 2007 | 04:48 PM
ToocoolZ28's Avatar
This just started all of a sudden, when I push the clutch pedal to the floor I get a very loud grinding noise, if I hold it all the way down it will almost kill the engine. It does it in all gears and neutral. I have heard bad throwout bearings before but nothing like this. I wonder if it could be the throwout bearing or even the pilot bearing. If I only push the clutch pedal down about halfway I can still drive it, no grinding and all the gears work fine. Its a 95 Z28 6 speed with 250000 miles on it but the clutch was replaced about 3 years ago.
Anyone have any ideas.
Ron
Old Nov 17, 2007 | 04:52 PM
OBE1 95Z28's Avatar
Could be the clutch fork interfering with the clutch assembly; the pivot point for the fork may be loose causing the fork position to change. Remove your slave cylinder and inspect the fork (what you can see of it).
Old Jan 13, 2009 | 12:27 AM
CreatiVe2's Avatar
any resolution to this?
Old Jan 13, 2009 | 09:02 AM
ToocoolZ28's Avatar
The bolts holding the slave cylinder had backed out and were rubbing on the pressure plate.
Ron
Formula Steve
Sep 19, 2023 08:31 AM
IndyZman
Oct 22, 2015 02:17 PM
Bxlt1
Sep 29, 2015 03:18 PM
4586
Sep 27, 2015 01:55 PM
