s60 and pinion angle
Old Mar 30, 2010 | 08:49 PM
chevyrules85's Avatar
yes ive searched but not much info on the 60
ive read that the pinion is slightly offset in the strange s60, and just wondering if i need to account for this or not?
heres the deal - ive got adj. lower arms and PHB, and adj. TA. and im not to sure where to start to set up the rear of my car.
where do i set the control arms at for a good starting point?
from what ive gathered you want your trans and rear to be parallel ideally.
ive also got the relocation kit from UMI and just wondering which holes i should use in that bracket? theres like 4 different settings...
i pretty much just need a base line or a starting point to go off, any help is much appriciated, thanks!
Old Mar 31, 2010 | 08:26 PM
anyone? gonna try settin this thing up tomorrow...
Old Apr 1, 2010 | 06:46 AM
AL SS590 M6's Avatar
Moderator
nothing to do
center the axle in the wheelwell then measure carefully to the front wheels to make sure that the axle measures the same on each side.
Yes, to start with then you need to tip the front of the pinion down 2 to 3 degrees
For all out straight line traction use the bottom holes. To set up for spirited driving use a hole that makes the LCA parallel to the ground or just a tiny bit lower at the rear mountint point.
read inserted notes.
Old Apr 3, 2010 | 11:00 AM
thanks for the help man, you said yes to start with making the trans and rear parallel... how do i go about doing that?
Old Apr 4, 2010 | 06:23 AM
Moderator
Angle finder on the face of the tail housing of the trans, compare that to the face of the rear end yoke. Using your adjustable torque arm make those read the same then adjust the rear end angle down a couple of degrees.
Old Apr 8, 2010 | 01:36 PM
firebirdStud's Avatar
al, what do you mean by "face"? Really curious here...
Old Apr 9, 2010 | 06:45 AM
Moderator
I always set pinion angle before installing the driveshaft so that I can put the angle finder on the rear face of the trans where the seal goes in. Not on the seal but right beside it. That surface is 90° to the centerline of the output shaft.
Old Apr 9, 2010 | 01:19 PM
ahh, ok. That makes sense. What do you mean by face of the rear end then?
Old Apr 9, 2010 | 02:14 PM
doesnt the output shaft of the trans stick out past that point, and if it does could you just use the very end of the output shaft?
the face of the rear end, you mean the part of the yoke where the u bolts go into the yoke? and just make sure its perfectly vertical?
Old Apr 10, 2010 | 06:09 AM
Moderator
With a machined yoke you can use the surface where the U-bolts go thru. If it's a rough cast yoke and the base of your angle finder is small like mine you can sit it right in where the u-joint caps sit after using it to index the yoke to perpendicular.
Old Apr 10, 2010 | 03:43 PM
Ill have to look at mine and see what I can come up with. good stuff in this thread! Thanks!
Old Apr 11, 2010 | 09:53 AM
well, I finally have my torque arm set up properly. the harmonic damnper was at 86.5 degrees, and I set up the rear to be at 87 degrees to have a half a degree pointing down when compared to the trans. Since this is a daily driver, I didn't want much more. I will add degrees when I go to the track though.
Problem is, vibration is still there.
Thanks for the help with this though!
kozmosis
14
Jan 20, 2016 01:48 PM
Bobczar
Oct 23, 2015 11:22 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
Aug 7, 2015 01:26 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
