ring gear was loose...why?
Old Sep 5, 2006 | 07:38 PM
fstenuf's Avatar
well i had this nasty noise in my rear, found out it was the ring gear not tight at all. so i had it tightened. now my gears whine/howel a little bit. also my pinion seal leaks quite a bit. how do i get it to stop? is my driveshaft angle wrong? also how much is a rebuild kit for a moser 12 bolt? what else could it be? thanks!
Old Sep 5, 2006 | 07:40 PM
wrd1972's Avatar
Re: ring gear was loose...why?
Did you red loctite the bolts?
Did you torque them to 65 lbs. ?
These are the only reasons a ring gear will loosen.
Consider your gears to be shot.
DirtyDaveW
Mar 15, 2015 07:01 PM
1963SS
Feb 6, 2015 10:05 AM
ChrisFrez
Feb 1, 2015 08:26 AM
