Richmond Gear Noise.
Old Nov 2, 2007 | 11:56 AM
Rich_z28's Avatar
I finally buttoned it up lastnight and drove it for the first time with the 3.73 Richmonds in it. Just curious as to how much noise is ok? I have no noise will accelerating, but I do have a mild whine on the coast side of the gears. I've got them set at 12 thousandths backlash just like Richmond calls for but I have been told that is too much that I should back it down to 5-7. The GM specs on stock gears is 5-9 thousandths. The pinion is shimmed to the same depth as stock. Any ideas if this is ok or should I do some adjusting? Thanks.
Old Nov 7, 2007 | 11:44 AM
Rich_z28's Avatar
Angry
Well I tore it back down this weekend set the back lash to around 6-7 thousandths and still have the whine. Any ideas? The pinion is set at 30 thousandths. According to Richmond these are good tolerences. It just seems a little too loud to me. THanks.
Old Nov 7, 2007 | 12:19 PM
jay_lt4's Avatar
any pics of your gear pattern when you set them up?
Old Nov 7, 2007 | 01:06 PM
RUDEDOG's Avatar
I had a coast whine after changing a pinion seal. I had the pinion too tight. Backed off pinion nut a tad and noise went away. Still quiet after 40k.
Old Nov 7, 2007 | 02:45 PM
Rich_z28's Avatar
I'll check that. thanks
Old Nov 7, 2007 | 02:46 PM
Rich_z28's Avatar
no, I don't. wish I did have. They looked fairly good though.
Old Nov 7, 2007 | 03:37 PM
87DJP2001's Avatar
Richmond gears are noisey because of the cut of the gear teeth which was ment for racing. Your set up may be fine but that is the nature of those gears.
oldschool
Feb 9, 2016 09:21 PM
akwa
Apr 5, 2015 05:09 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
jj71787
Dec 30, 2014 02:15 PM
squarehead
Nov 21, 2014 08:02 PM
