Reverse gear slippling
Old Jun 2, 2004 | 05:31 PM
94z_convertible's Avatar
I have a 94 z28 A4 . When I put it in reverse, it takes about 10 to 15 seconds just to engage. After it finally engages, I can barely push down on the gas or it slips really really bad. I can't even back up with the front wheels turned very sharp. Other than reverse, the transmission acts perfect. Drive never slips and shifts through all the gears just fine.
Is there anything short of a rebuild that could correct this problem?
Old Jun 2, 2004 | 09:54 PM
GreenDemon's Avatar
Check to make sure your fluid is at the right level...
Other than that...
At least it's reverse. I could probably go without that for a while. I'd save up for a performance rebuild from a reputable place. In the meantime, if it goes out, you can park on a hill, park so you can drive straight out, or if all else fails, just push the sucker out if you're not easily embarrased by the condition of your car.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
alex5366
Apr 1, 2015 09:27 AM
Victory Racing
Sep 1, 2002 05:34 PM
