Reprogramming for a 3500 stall TC?
Old Mar 3, 2004 | 10:02 AM
fastcamz28's Avatar
Getting ready to replace my current A4 w/ a high performance 4L60E and 3500 stall TC. This goes in a '94 w/ OBD1. What, if any, shifting problems can I expect due to a stall >3000 and do I need to have the PCM reprogrammed for a stall this high? Have done a search and didn't gain a clear-cut answer.
Thanks!
Old Mar 4, 2004 | 09:33 AM
fastcamz28's Avatar
Anyone?
Old Mar 4, 2004 | 11:05 AM
hot_red_z28's Avatar
Yes, you should get reprogramming done.
Reason 1:
With any stall close to or greater than 2800, you run the risk of possibly having the "stall wall" problem of the odb1 computer. This could mean your engine will bounce off the rev limiter at WOT cause the tranny doesn't shift. It could also cause the computer to put your car into limp mode, setting an SES code and sticking you in the 1:1 gear for the rest of the drive home. If any of this occurs, you definately need the "stall wall" fix.
To my understanding, only about 10% of cars have the stall wall issue, and only about 10% of those cannot be fixed. The odds are, you'll be fine by just throwing it in, but you never know.
Reason 2:
Better performance through tweaked shift points, etc...
Old Mar 4, 2004 | 11:19 AM
fastcamz28's Avatar
Thanks! I've put in a call to Bryan @ PCMforless.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
