replacing pro-5.0 shifter springs??
Old Mar 26, 2006 | 10:58 AM
  #16
Hawk's Avatar
Re: replacing pro-5.0 shifter springs??
I called pro50. I talked to the guy about it he sent me new springs. I'm going to install the new ones and see what happens, if it's still not springy enough, I'm going to put some washers in there.
Also note, for anyone trying to change springs, there is some kind of "insert" that he is also sending me that sits on the bottom of the spring. It's supposed to stop the spring from getting damaged. I didn't see this in my pro50 when I took it apart, maybe this was my problem?? we'll see.
Old Mar 26, 2006 | 11:14 AM
  #17
97FormulaWS-6's Avatar
The insert that is supossed to be under the springs is like a solid-washer which is what rides on the cross-shaft of the shifter. If you didn't have these, then the springs will get damaged very easially.
Old Mar 29, 2006 | 11:51 AM
  #18
Hawk's Avatar
replaced the springs. The shifter is MUCH better, feels new again. I guess after 4-5 years the springs get worn down alot!
Old Mar 30, 2006 | 11:08 PM
  #19
JoeliusZ28's Avatar
thats interesting, i didnt even see any springs in mine when i installed it. thats good to know though in case mine ever gets weak.
nikolt1
Feb 27, 2015 09:10 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
