Replacing C-clips. Need part#
Old Apr 7, 2006 | 11:37 AM
LA_TA1's Avatar
I will be replacing the c-clips on my stock 10 bolt rear w/ 2.73s and limited slip this weekend. Does anyone know the part numbers for the c-clips and any other parts I may need? If anyone has done this before has any advice that would make the job flow smoother they are more than welcome to share it. Any help is greatly appreciated.
Old Apr 7, 2006 | 12:35 PM
87DJP2001's Avatar
Re: Replacing C-clips. Need part#
Why do you want to replace the C-clips on the axle shafts??
Its not like they are a wear item.
87DJP2001's Avatar
Old Apr 7, 2006 | 01:09 PM
LA_TA1's Avatar
My rear axle some play in it so the rotors rub against the calipers especially after taking a turn. I had read up on the subject on this board a while back and I remember a few people saying that replacing the c-clips would solve this problem.
Old Apr 7, 2006 | 02:42 PM
87DJP2001's Avatar
I would do a little more reseach. The C-clips have nothing to do about your problem.
Old Apr 7, 2006 | 03:34 PM
LA_TA1's Avatar
Thanks for the replies. Due to your post I did more checking and found a few simpler things to try first that should solve the problem.
Old Apr 8, 2006 | 07:44 PM
simz28's Avatar
My rear end is doing the exact same thing. I dont know what to do. What were the other things that you were going to try to solve this? Thanks
Old Apr 9, 2006 | 06:39 PM
BlackDog's Avatar
Like it was said, the c-clips are not the trouble. But he is the part # anyway.
344171
I would think the problem would be the bearing and race are worn.
KYWes
Apr 15, 2015 05:48 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
4586
Feb 14, 2015 01:40 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Hurin
Dec 13, 2014 07:38 PM
