Replacement transmission line options? Part #'s?
Old 02-27-2007, 09:49 PM
Moderator
Javier97Z28's Avatar
I cut my factory flare fittings off b/c they were rounded out from excessive use.
I reflared the fitting but I'm not happy with the way it came out, I don't want to risk anything with the transmission so I'd rather just replace everything.
My two options are:
Go to the dealer and order a new set of lines (I need a part number if anyone has it)
or
Replace it with AN fittings and line (expensive $$$)
If I go AN I do not want to replace the case fittings, I absolutely will not risk cracking my case at this point. I know the earl's part # for the inverted flare, but I have no idea how to make AN line, what I need, or where to start. If anyone has a list of all I need it'd be great.
Or, if someone has the GM part #, that'd be great.
Javier97Z28 is offline
Old 02-27-2007, 11:18 PM
Moderator
Blah, I'm gonna use this:
And splice into the lines with the supplied compression fittings. Cheap, should be quick with a tubing bender. It'll make future removal easier.
Old 02-28-2007, 08:39 AM
Moderator
Napa doesn't have the above kit in stock, so if I'm gonna do this today I'm gonna have to try my luck with their 5/16" brake line w/ double flares and use some compression fittings.
10-31-2016 11:09 AM
Jazsun
12-29-2014 12:14 PM
BIGCOWL-IMP
12-19-2014 06:59 AM
Quick Reply: Replacement transmission line options? Part #'s?
