Replaced broken tranny mount with poly one
Old 06-06-2006, 11:24 PM
James Montigny's Avatar
Uhm,
I think the old was needed replacing.
What do you guys think?
James Montigny is offline
Old 06-06-2006, 11:41 PM
1FstFormulaV8's Avatar
Re: Replaced broken tranny mount with poly one
I've broke so many of those I actually made a jig for the tranny and floor jack.
1FstFormulaV8 is offline
Old 06-06-2006, 11:45 PM
I did too, I call it a 2x8
Old 06-07-2006, 02:59 AM
1racerdude's Avatar
Poly will vibrate it's *** off and yours too.
1racerdude is offline
Old 06-07-2006, 06:12 AM
Jeff95TA's Avatar
That's what mine did. Seems to vary from car to car (or maybe some people are just more tolerant of the vibration).
Jeff95TA is offline
Old 06-07-2006, 06:29 AM
GetaZforgetGT's Avatar
Did you have poly engine mounts and poly trans or just a poly trans mount?
I've heard others say that it vibrated alot until they went poly in both (all three mounts, obviously) locations.
GetaZforgetGT is offline
Old 06-07-2006, 06:56 AM
Vibration is no problem at all.
I've had these on at least two Fbodies without issue.
Old 06-07-2006, 07:07 AM
mccullar_racing's Avatar
Now whats a muscle car without some good vibrations?
mccullar_racing is offline
Old 06-07-2006, 11:02 AM
stik6shift93's Avatar
helps if you run an aluminum driveshaft, with the steel one it can be hit and miss depending on how bad the balence is off.
stik6shift93 is offline
Old 06-07-2006, 05:59 PM
eagleknight97's Avatar
Also depends on the company that makes it, and if its ES, then if you use the spacer plate, it will vibrate much more.
eagleknight97 is offline
Old 06-07-2006, 09:24 PM
justcallmebo's Avatar
Used the spacer plate on '97 A4 Z - vibrates very bad with poly mount. Thinking of going back to rubber..............
justcallmebo is offline
Old 06-07-2006, 10:18 PM
xpndbl3's Avatar
those break sooo easily with just the slightest bit of power put to them, poly is the only way to go.
xpndbl3 is offline
Old 06-08-2006, 12:47 AM
Do NOT use the spacer plate, i had it in there for a year because I thought it was supposed to be in there and when i finally found out it wasnt, i took it out and boom...WAYYYY better. Compared to before, car felt like a luxury car when it idled.
Old 06-08-2006, 02:14 AM
1racerdude's Avatar
A smooth driving car!!!!!!
Old 06-08-2006, 06:29 PM
MeanGreen97Z's Avatar
That old Mark Wahlberg song popped in my head.... its just some good vibrations, come on come on come on .... feel it feel it! feel the vibrations!
MeanGreen97Z is offline
Quick Reply: Replaced broken tranny mount with poly one
