Removing T56 -- help please!
Old Oct 27, 2007 | 03:16 PM
JakeRobb's Avatar
Super Moderator
Okay, so I'm almost done removing the T56 from my Z28.
We have the separated from the bellhousing, and the trans is sitting on the trans jack. The only thing keeping me from lowering the trans and being done (for the day) is disconnecting the hydraulic line from the slave cylinder.
Some searching yielded this sticky on LS1Tech:
http://www.ls1tech.com/forums/showthread.php?t=779117
Step 13 of that sticky says:
13. Push the little tab on the connector of the master braided line and then pull the line out of the slave and tie it off out of the way.
Here's a picture of the braided line where it goes into the slave cylinder:
I've pushed and pushed on the little plastic ring around the line, and pulled on the braided line at the same time. Like you do with quick-disconnect air fittings. It hasn't moved at all. The plastic ring spins easily around the rest of the assembly.
Can anyone help? Thanks!
Am I doing it right, and just not pushing/pulling hard enough?
Old Oct 27, 2007 | 06:21 PM
mdacton's Avatar
push in on the line when you push the plastic in.......try to do it like a man.
Old Oct 27, 2007 | 09:31 PM
ws6transam's Avatar
You've been pushing on the plastic ring, but what about pushing in on the plastic tab itself? Wow, you are so close!!
Old Oct 27, 2007 | 09:44 PM
dangalla's Avatar
i think this may be your prob. push the line into the fitting first
Old Oct 28, 2007 | 05:10 PM
Fuelman's Avatar
I had to open the bleeder to push the fitting in to remove it.
Old Oct 28, 2007 | 08:16 PM
Capn Pete's Avatar
You have to push that plastic ring as FAR IN as it will possibly go, and even then, it still takes some wiggling and pulling to get the line out (and as you're pulling the braided line OUT, make sure that plastic ring stays IN, otherwise it'll still cause you problems).
Old Oct 28, 2007 | 10:00 PM
ws6transam's Avatar
Jake figured out a different solution: It was easier just to pull the two bolts and slip the throwout bearing assembly off the front of the transmission without disconnecting that line.
Old Oct 28, 2007 | 10:33 PM
Capn Pete's Avatar
That'll work too!!!
Old Oct 29, 2007 | 06:58 AM
JakeRobb's Avatar
Super Moderator
Yep, I was going to post that this morning. Dan beat me to it!
Thanks a ton, Dan, for your help and for letting me borrow your tools!
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Jul 10, 2015 06:29 PM
birdblack
Jul 8, 2015 07:23 AM
cmdeshon
Dec 27, 2014 10:06 AM
