Removal of Backing Plates?
Old Dec 15, 2004 | 10:25 AM
TUFF LT1's Avatar
Getting ready to drop the old 10 bolt for a 9" and had a question that may sound a little dumb. I don't know what the backing plates are...and how do I remove them. I did a search but all i could find was that the calipers bolt to them or something??? Thanks in advance.
Old Dec 15, 2004 | 10:39 AM
GREGG 97Z's Avatar
Re: Removal of Backing Plates?
The backing plates bolt to the ends of the axle "tubes" of the rear housing. There are 4 bolts that hold that to the tubes. Yes the plates are what the two bolts on the brake calipers mount to. If your 9" doesnt already have backing plates (it might) you need to remove them from your old rear. It involves removing the C-clips from each axle (inside the 10 bolt cover) and pulling each axle along with unbolting the backing plates. I've had a Moser 9" and now a 12 bolt and they both came with backing plates, although each of the rears were used, not new. Not sure how they come from Moser.
Old Dec 16, 2004 | 09:43 AM
TUFF LT1's Avatar
OK, thanks for clearing that up for me GREGG 97Z!
Old Dec 16, 2004 | 10:38 PM
camaroz28_97's Avatar
my 12 bolt didn't come wiht them so i needed to take them off the stock rear. did you get the c eliminators?? if you did you need to do a little moding to those backing plates
Old Dec 17, 2004 | 08:39 AM
TUFF LT1's Avatar
Nope, I didn't get the C-eliminators. I got a moser 9" though But thanks for the heads up on the modding.
Chet1185
Feb 4, 2015 09:51 PM
alphaauto
Jan 23, 2015 07:42 AM
ddr698
Jan 9, 2015 10:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
firebirdude
Aug 7, 2002 07:31 AM
