Reluctor ring position(3ch abs) question
I am putting together a spare 7 5/8" 10 Bolt rear end with 4.1 gears, Eaton Posi LSD, alumium cover, etc.
I noticed that the reluctor ring is not aligned with the ABS sensor in the Diff Housing. The metal center part of the sensor does not sit in line with the reluctor gear. they are side by side. Is this the way it is supposed to be or should they line up and ovelap?
Thanks for pointing that out, Fred. That is precisely what happened. I am trying to use a series 2 reluctor ring in a series 3 carrier.
The series 2 reluctor ring is thinner and does not overlap the sensor.
I will try to move it further or get a series 3 (wider) reluctor.
ChrisFrez
02-01-2015 08:26 AM
squarehead
01-15-2015 07:02 PM
