rebuilt Trans no forward
Old 05-09-2013, 10:51 AM
Chet1185's Avatar
Just built my 4l60e, I have reverse but no forward. I went by the book so I don't understand what happened.all the areas that needed special tools I had someone do for me. New molded pistons, zpak, all new frictions.
What could be wrong?
Posted from Camaroz28.com App for Android
Chet1185 is offline
Old 05-09-2013, 11:19 AM
12SCNDZ's Avatar
Re: rebuilt Trans no forward
There are numerous things that could be wrong. Anything would only be a guess right now. Most likely something in the forward clutch area. Was the forward and over run air check good?
Frank
12SCNDZ is offline
Old 05-09-2013, 11:22 AM
Chet1185's Avatar
everything air checked great. I was thinking maybe the valve body bolts but I followed the paper that came with the rebuild kit.
Chet1185 is offline
Old 05-09-2013, 11:28 AM
12SCNDZ's Avatar
If you're thinking a bolt is in the wrong place, I don't think that's your problem.
Frank
12SCNDZ is offline
Old 05-09-2013, 11:34 AM
Chet1185's Avatar
so pretty much what's my best bet? tear it out and apart again? I have no idea what i'm even looking for. This sucks.... the last one I built had no reverse now that's all I have in this one
Chet1185 is offline
Old 05-09-2013, 02:13 PM
Chet1185's Avatar
Anything to check before I tear it out that would cause this?
Chet1185 is offline
Old 05-09-2013, 02:22 PM
12SCNDZ's Avatar
Did you air check the drum through the pump?
Frank
12SCNDZ is offline
Old 05-09-2013, 02:28 PM
Chet1185's Avatar
Yes. Everything tested good, so I think. I'm not skilled in this department lol
Chet1185 is offline
Old 05-09-2013, 02:53 PM
12SCNDZ's Avatar
Did you make certain the drums were all the way seated? Does it try to move backwards in neutral?
Frank
12SCNDZ is offline
Old 05-09-2013, 08:51 PM
Chet1185's Avatar
No it doesn't. I could have sweetie when I put it in park I felt the slightest engagement. May be wrong though
Chet1185 is offline
Old 05-10-2013, 12:42 AM
Chet1185's Avatar
Lol swore
Chet1185 is offline
Old 05-10-2013, 07:22 AM
12SCNDZ's Avatar
Put a pressure guage on it and see if you have pressure in any forward ranges.
Frank
12SCNDZ is offline
Old 05-10-2013, 04:43 PM
Chet1185's Avatar
Air tested before valve body install and it worked.
Chet1185 is offline
Old 05-12-2013, 11:13 AM
Chet1185's Avatar
Forgot the small input sun gear or whatever its called I forget.lol
Chet1185 is offline
Old 05-12-2013, 11:29 AM
12SCNDZ's Avatar
Well, um... That will definitely cause a no forward condition. Didn't you notice you had leftover parts after you got it together?...LOL
Frank
12SCNDZ is offline
Quick Reply: rebuilt Trans no forward
