Which rebuild kit???? help
Old May 28, 2013 | 02:41 PM
jdeaton01's Avatar
i have a 94 z28. i have the 4l60e out and torn down into the sub units and im looking for a rebuild kit. i dont know which one to choose. i have been looking at two.
This one
Trutech Trans 94 96 4L60E Raybestos Z Pak Zpak Friction Rebuild Overhaul Kit | eBay
or this one
4L60E 4L60 E 1993 1996 Transmission Master Rebuild Kit Overhaul GM Automatic | eBay
or if anyone has some suggestions about another kit let me know thanks.
And i need a torque converter. i Just want it back a little better than factory
Old May 30, 2013 | 09:23 AM
Pro Built Automatics's Avatar
Re: Which rebuild kit???? help
If you want the most complete kit and custom tailored (matched) to what you have, what has been done to he motor, rear end gear ratio, torque converter stall and diameter, and what the vehicle is used for. Then go to: https://www.700r4l60e.com/store/home.php?cat=22 This will give you the choices you need to do this right the first time. Call me with any questions 909 795-1876.
blac94Z
29
Mar 25, 2015 04:21 PM
armedtrigger
Feb 24, 2015 08:30 PM
chuyz28
Nov 25, 2014 11:14 PM
