Which rebuild kit???? help
i have a 94 z28. i have the 4l60e out and torn down into the sub units and im looking for a rebuild kit. i dont know which one to choose. i have been looking at two.
This one Trutech Trans 94 96 4L60E Raybestos Z Pak Zpak Friction Rebuild Overhaul Kit | eBay or this one 4L60E 4L60 E 1993 1996 Transmission Master Rebuild Kit Overhaul GM Automatic | eBay or if anyone has some suggestions about another kit let me know thanks. And i need a torque converter. i Just want it back a little better than factory |
Re: Which rebuild kit???? help
If you want the most complete kit and custom tailored (matched) to what you have, what has been done to he motor, rear end gear ratio, torque converter stall and diameter, and what the vehicle is used for. Then go to: https://www.700r4l60e.com/store/home.php?cat=22 This will give you the choices you need to do this right the first time. Call me with any questions 909 795-1876.
