rearend noise
rearend noise
When turing slowly left or right i hear a slight squeeking / rubbing coming from the rear end its not very loud but noticable at low speeds seem to come and go whenever it pleases sometimes it does it and sometimes it wont. Does this sound like the posi isnt unlocking or something.
I was thinking changing the fluid and putting some additive in there or do you tihnk its a more serious problem
Re: rearend noise
If you do a search to confirm this, you will find that this is a fairly common problem. Most find a solution in changing the differential fluid and adding a bottle of GM addititive when you do. Seemed to have fixed mine when I was having the same problem. Some will also recommend not putting a synthetic fluid in when you change it out.
autoxr166
Sep 25, 2015 04:21 PM
colts0455
13
Aug 7, 2015 09:15 PM
