Rear ends?
Re: Rear ends?
Running a Moser 12 bolt for 7+ years now. Running good behind a 383-D1 MM6 97"SS. I optioned it up a bit to $2700~. I went with a Tru-Trac diff 33 spline unit and 3.73:1 gear. Great torque bias around the corners. Fit up good except for the rear brake line bracket. Did some fab there, but not difficult. Mail ordered from Moser and picked up with the truck @ freight depot.
You need a press to assemble the axle bearings. Or, have it done @ many available shops. Axles go in very easy. No "C" clips for axle removal and maint.
It takes all the abuse I can dish.
B.
B.
Re: Rear ends?
The Strange is fully assembled, lubed, run in at the factory. Total plug-and-play. The Strange also uses the stock style through-bolts for the torque arm. The Moser uses individual bolts top and bottom. They have a tendancy to come loose, and some torque arm manufacturers will not warranty their products with the Moser. Some people with the Moser have had problems with the driveshaft length not matching stock, but if you're buying a new rear axle assembly, you would probably buy a new DS as well.
Re: Rear ends?
The Moser 12 uses the gm 7 1/2" caliper plates. They have to be assembled onto the axle's and bearings pressed on. So, when you receive the shipment, axles are seperate from the housing. About $20 an axle for a shop press. I had a press so zero dollars. The rear bolted in as an assembled piece, then you insert the axles. Brake hook-up the way you want. Many use tie-wraps, but I fabbed some brackets.
I reused the gm stock rear disc brakes. No lube, so I had to do that. I purchased a new DS from Denny DS Service. HD Alum about $500 with 1350 yoke. Very nice shaft.
The oil vent must be located high. I used a plastic hose. Also, when lube filling, use the side port to gage case fill. Moser rears can emit lube when over filled.
Torque arm bolts can come loose. I used red lock-tite. No problems with bolts falling out. It is wise to check the after-market torque-arm bracket hole size so it will match the Moser bolt size. I have a Random-Tech Arm, so, I made some bushings to take out clearance since it was designed for the stock thru bolts. Lots of load @ those bolts.
Better than the 7 1/2" rear.
B.
B.
Re: Rear ends?
I will be purchasing a rear end come income tax time, i have seen prices from 2200 to 3200 shipped. Anyways this is going to be a street car that will see maybe a couple of strips at best. Id really like to save money if possible I do not want to have to rebuild the whole thing, as Ive never even touched an assembly till about a month ago.
Biggest note, I do not want to take off one day and have to worry about the rear end blowing out. I want something thats gonna last. As well as of now my thoughts are this car will never see over 400hp. Any inputs great input thanks everyone.
One last peice of advice: Take your time and choose wisely, think about overall goals of the car and customize based on that. Hindsight, I would have had mine narrowed 2" or 3" per side so i could get some cheap 15x10 rear wheels that I'm itching for now.
Re: Rear ends?
If you have a T56 manual trans, don't bother with a 12bolt- go with the 9" or S60. If you have an A4 then the 12 bolt will suite your need just fine. I like my S60 with trutrac and put about 6k street miles on it so far. The only complaints are- 1. had slight whine between 45-50 (installed louder exhaust to fix that) and 2. Had a pinhole leak from a weld on the outer axle housing (JB welded and touchup paint to fix). Still haven't been to the drag strip on it yet.
Re: Rear ends?
B.
B.
If you could though tell me more about the driveshaft you purchased pros and cons what I should look for?
Re: Rear ends?
Re: Rear ends?
There are many driveshaft companies out there that can built you a nice strong piece. I personally had my local shop build me one. He has put them in 8 second drag cars and was confident I wouldn't break it. In fact, he told me if I did to bring it back and he would build me a new one for free. The welds on it were perfect- I have seen robots that couldn't weld as nicely.
If you want lighter, go with Alum or Carbon Fiber. If you want the strongest go with steel.
Re: Rear ends?
I'm not trying to "touche'" anyone... just providing info.
The March 2011 issue of GM High-Tech Performance magazine has an article on installing the S60 in a 4th Gen. See page 58.
