Rear End Weeping...
Old Sep 25, 2004 | 04:30 PM
Pandamonkey's Avatar
Unhappy Rear End Weeping...
My car has been sitting idle for the last month due to poor weather.
Today I was taking a look at it and I noticed a puddle of oil near the back of the car.
I guess it would be the rear end leaking.........seeing as how there isn't any other sources of oil at the back.
Easy fix?
Could it be just a gasket?
Old Sep 25, 2004 | 05:24 PM
95_LT1_6SPD's Avatar
Re: Rear End Weeping...
most likely the pinoin seal. See if its wet at the front where the ds goes in or around the cover. Mine leaks from the pinoin seal a few drops a week, not worth fixing it to me.
Old Sep 25, 2004 | 05:36 PM
Yup - looks like it's the pinion seal......
If I end up getting it fixed - I guess I should throw in 4.10's.
Old Sep 26, 2004 | 02:58 AM
Z95m6's Avatar
You can fix it with out removing the gears. It doesn't take very long at all.
Old Sep 26, 2004 | 06:56 AM
ABA383's Avatar
Get a GM seal. Its got a bead of sealant around the outside of the seal where it meets the housing, which is also a source for leaks...
--Alan
Old Sep 26, 2004 | 10:28 AM
Aw damn.............really?
I've got a whole year of warrenty left on my car and was hoping they would have tear apart and put back together my rear end in order to fix it............while I purchase a new set of GM 4.10's and substitute them in place of my stock 3.42's......
But.......since you're saying the fix can happen without having to take it apart - I guess that's a dead end.
Is the fix that you speak of the absolute correct way to have it done - or is it the cheapest for the guy with not much money?
I don't have much money but..........I do have a warrenty.
Old Sep 26, 2004 | 11:02 AM
Z95m6's Avatar
The seal drives in from the front side of the housing so there is no reason to pull the rear cover and gears out. All you do is take the driveshaft off, remove the pinion yoke and then your staring at the seal. You could go borrow some sticky tires and kill your 10bolt if you wanted to. Thats not very hard.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
