Rear End Swap (LS1 to V6)
Old May 4, 2005 | 11:40 AM
JoeMack's Avatar
My son has a 99 v6, will the rear out of my 02 z28 bolt up to his? Bakes, ABS,U-joint, etc..
Old May 4, 2005 | 10:40 PM
respectirocz's Avatar
Re: Rear End Swap (LS1 to V6)
it should bolt right up
Old May 4, 2005 | 11:56 PM
1BAD86Z's Avatar
Does your car have traction control? I highly dought your son's does. The abs system might not be compatible with one car to the next.
Old May 5, 2005 | 08:33 AM
JoeMack's Avatar
Niether one has traction control, just ABS. Will that be compatable?
Old May 5, 2005 | 11:01 AM
1BAD86Z's Avatar
Yes, both cars will have the ABS on top of the center of the housing. It will bolt righ in, but one more thing, is the V6 car a drum brake car?
Old May 5, 2005 | 01:13 PM
cdcamaro95383's Avatar
What problems could the drum brakes on the V6 cause. I have a 93 Z rear end im wanting to put in my 95 V6. One reason is for the disk brakes, and second is the fact that im planning an engine swap soon. Will I need to swap the whole brake sysytem form my Z?
Old May 5, 2005 | 04:45 PM
1BAD86Z's Avatar
The brake proportioning valve would have to be changed cause the disc require a different amount of pressure to operate.
Old May 5, 2005 | 06:07 PM
Mike94ZLT1's Avatar
Scott couldn't you just get an adjustable one and put it in line?
Old May 6, 2005 | 12:07 AM
1BAD86Z's Avatar
Sure you can.
Old May 6, 2005 | 08:53 PM
JoeMack's Avatar
Nope, disks all around
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
