does some one know how much gear oil and additive do i need to put do a comlete rear end oil change?
check brent's site
lt1 tech moderator
lt1 tech moderator
It should take about 1 1/2 quarts, if you don't have a zexel posi you'll also have to add the limited slip additive. I believe gm calls for 4 ounces of additive. With my ta girdle cover i can almost fit 2 quarts in, no additive though.
thanks on the info it has a stock posi with 4:10 gears and it's going in my a-4 . thanks again
