Rear End Gears :: Installation
Old May 18, 2007 | 08:06 PM
showstoppers-96-Z/28's Avatar
Ok, i recently had a thread discussing what 3.73's would do for me performance wise, and so being im convinced this is the ratio for me, i bought a set of richmond gears from summit and the complete installation kit (bearings, seals, shims, etc). locally i've priced some shops to do the work and the best offer is right at about $550. So now the burning question is has anyone here ever installed a set of ring and pinion gears in one of these cars? if so, can you give me a sort of "how to" description on the installation and propper shimming of the gears. maybe someone could give me an article or link to a set of installation instructions. and then again, given maybe from someones experience or an attempted install, doing it myself might be a bad idea? the past experience i have is installation of headers, a cam, opti distributor, removal of the intake manifold, i've installed a transmission in a 95 trans am. so...should i let the professionals do it or is this something i may be able to handle? id only have a time window of about one weekend
Old May 18, 2007 | 09:26 PM
Dave89IROC's Avatar
lots of speacialized tools and knowledge is needed, or the gears are ruined
I am ASE cetrified I hate doing them, I let someone who likes it do it
check the local forum(near you) for someone who does them, there is a couple guys up here near detroit, might be someone there by you
Old May 18, 2007 | 09:27 PM
You will need a dial indicator and a press for the installation. Do you have those tools?
You might find instructions with a search in the drivetrain forum, where this thread should be.
Old May 18, 2007 | 11:06 PM
sounds like a job for the pro's to me
Old May 19, 2007 | 12:55 AM
Z-RATED94's Avatar
That would be my thought too. Richmonds are known to be a little noisier then other gear sets, so a pro might have better luck setting them up. A few have claimed the Richmonds can be set up with very little noise, but I believe that is rare. The good news is, there stronger. PS, had Richmonds and the noise was to much for me. I went with Motives.
Old May 19, 2007 | 07:27 AM
PLEASE post in the correct forum. This did not belong in "LT1/LT4 Engine Tech".
Old May 19, 2007 | 09:08 AM
i will next time, i had no idea, plus it was late when i made the thread and all i had in mind was the "LT1 generation", so i'll be sure to post things like this in their propper forum
Old May 19, 2007 | 09:51 AM
STAYBG87Z's Avatar
main thing is to get your pinion depth right,if thats off your whole shiming and backlash will be off too.i've installed plenty of gears.also what series is your carrier?i think you will need a 3 series carrier if you have a 2.73 gear in it now,so you might have to buy a carrier,and i have one for sale out of a 87 iroc,posi unit too!
Old May 19, 2007 | 01:05 PM
bombebomb's Avatar
No, richmond makes 3.73 for a 2 series, I bought the same set he has.
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
