rear end gears
Old Jan 12, 2011 | 05:47 PM
jdelaprida's Avatar
rear end gears
I have a 96 camaro z28 convertible with a intake and cat-back slp exhuast.
What series rear would i need to get 3.73s?
What series stock do i have?
And im pretty sure i have 2.73s stock in my car now.
Old Jan 12, 2011 | 08:45 PM
RamAir95TA's Avatar
Re: rear end gears
If you have an automatic and there is no selectable first gear on the console, then you have 2.73s and a 2-series carrier. If first is selectable then you have 3.23s and a 3-series carrier.
If you're a stickshift, you've got 3.42s.
Either way you can order gears for either carrier.
Old Jan 13, 2011 | 07:24 PM
jdelaprida's Avatar
Re: rear end gears
yeah its automatic.
What do you mean if 1st gear is selectable? You mean if i can throw my trans into 1st?
Old Jan 13, 2011 | 08:00 PM
Re: rear end gears
Yes. The base model shifter indicater plate on the console starts with "2". That's the 2.73 rear car. The "performance rear axle" option gets you 3.23 gears, and the shifter indicater plate starts at "1".
Old Jan 18, 2011 | 11:19 AM
englundjd's Avatar
Re: rear end gears
in my car i have the 2.73 gears and the consul numbers only go down to second, but i can still select 1st gear, but back to the op question, you can order about any gear for that rearend
Old Jan 18, 2011 | 04:33 PM
koolaid_kid's Avatar
Re: rear end gears
The only thing keeping a 2.73 car from selecting 1st gear is a little plastic nub on the shift mechanism, which disappeared from my car over a decade ago. However, the console still only shows 2nd gear, just as Injuneer stated.
jdelaprida, you can purchase 3.73 gears for either carrier. If you car came with 2.73 gears, you need a set for a 2-series carrier. I run Strange, but I believe they are also made by Motive and Richmond.
If your car came with the less common 3.23 gears, you need a set for a 3-series carrier.
Old Jan 18, 2011 | 07:12 PM
jdelaprida's Avatar
Re: rear end gears
whats the ring gear size on a 96 camaro ?
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
