Rear End choice...
Rear End choice...
here are my RPO codes....
AU3 A31 A90 B35 B84 C49 C60 DG7 DL5
IPB J1F J65 KG9 K34 LT1 MX0 M30 NA5
R8S R8T STE T96 UB3 U1T U65 U73 VK3
1SK 14B 14I 41Q 41U 6HB 7HB 8TF 9TF
WA-U8555 14B
what do i need to get as far as option on the Moser 12-bolt? I will be going 3.42 or 3.73...haven't decided yet. not going to be used for track use....welll maybe once or twice...mostly daily driver. i will be getting the Eaton posi. i was just wondering if i need to get tcs or whatever other options there are...thanks in advance for any help provided!
WA-U8555 14B
Re: Rear End choice...
I'd go for 3.73. If you have traction control (aka ASR) there are two reluctors which need to be pressed on the ends of the axles. You can re-use the old reluctors, but that is kind of a pain and new ones are ~$75. If you don't have ASR, just be sure to tell them you want the single, sifferential mounted ABS reluctor included, assuming you want to keep ABS functionality.
Talking to them is a good idea, they know this stuff pretty well. As far as other "options", you can get one of those trick aluminum covers. Mostly just eye candy though they do provide some additional support. You also need to select axle size, you don't need more than 31-spline. You also should get the rear end with C-clip eliminators. Much safer for high performance use.
Don't forget that you will also need a new driveshaft. This is best ordered after installing the rear end and measuring.
Rich
Rich
Your car is pretty much stock and you say you're only going to the track a couple times, why even spend $2k or more on a rear end. The stocker will be fine unless you drive on the street on MT ET Streets.
