rear end
Old Sep 30, 2004 | 04:06 PM
cndctrdj's Avatar
rear end
ok heres the question. i was looking for the cheapest and safest way to upgrade my rear end. i dont have 2k for a full axle but i do have a few hundred dollars for a kit like this one http://www.thunderracing.com/catalog...&vid=4&pcid=68
is this any better than what i have on thier now (stock) or should i save up and buy something else?
any other thoughts would be much appreciated.
i use the car for mostly just regular travel, but like to hit the gas once in a while and do some street racing and some drag racing at the track. i will be getting DR's soon and my rear is making noise already when i turn a corner.
Old Sep 30, 2004 | 04:33 PM
87DJP2001's Avatar
Re: rear end
Why do you think you need a new rear??? A 10- bolt is strong enough for the average driver ( all 4th gen car except the SLP cars have the same rear.) unless you are abusing it. What do you call a strange noise, it really could be the limited slip digging in if you are on the gas.
Spend your money on something else. My opinion.
Old Sep 30, 2004 | 06:10 PM
cndctrdj's Avatar
Re: rear end
thier are all kinds of noises comming out of the rear end of my car. normally when i am coasting around a corner in a parking lot
Old Oct 1, 2004 | 08:05 AM
camaroKid223's Avatar
Re: rear end
id like to know about that kit aswell.
Old Oct 1, 2004 | 05:44 PM
n2ceptor's Avatar
Re: rear end
That kit 400
new posi 439
install 175+
total 1014 give or take to update a 10 bolt... Not including axles...
Old Oct 1, 2004 | 06:06 PM
cndctrdj's Avatar
Re: rear end
is the posi different than the gears
cause the kit gives you gears
and i figured it was pretty complete
i can install it on my own
Old Oct 1, 2004 | 06:25 PM
n2ceptor's Avatar
Re: rear end
MOTIVE Gears, in your choice of ratio...3.42, 3.73 or 4.10
Or, STRANGE Gears (2 or 3 series carrier) for $35 additional
RATECH Complete Gear Installation Kit
2 Quarts RED LINE Synthetic Gear Oil
1 Bottle GM Limited Slip Differential Additive
TA Performance Rear End Cover Girdle
TA Performance Stud Kit
If you are going to this mush trouble, change out the Limited Slip Differential(aka Posi) with a stronger unit, like Easton... The kit above just changes gears and bearings...
If you have never done a gear change before, its better to leave it up to the pros that do it everyday.... It appears easy, but its not...
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
