McCleod Street Twin in a stock LT1 car?
Old Oct 1, 2004 | 12:25 PM
96formulaLT1's Avatar
My stock clutch is starting to slip after my first time at the dragstrip and i am thinking about replacing it with the street twin setup. i understand that it comes with a new master cylinder, flywheel, clutch disks and pressure plate. is this a bolt in installation that i can do myself or do i need to have anything balanced? my car wont see the dragstrip again with this setup until i get a new 12bolt in a few months. will the street twin be to much for the rest of my driveline as long as i dont hammer it to hard?
Old Oct 1, 2004 | 12:57 PM
chris96ta's Avatar
Re: McCleod Street Twin in a stock LT1 car?
I just had the street twin installed on my car with stock drivetrain and it works great. I think it is a good idea to not take it to the strip with sticky tires until you get the 12 bolt. You might want to get a stronger driveshaft also. You should be fine on the street as the tires will break loose before you hurt your rear end.
Old Oct 1, 2004 | 01:42 PM
ah thanks, thats good to know.
also, would i need to get the neutral balanced kit or the regular kit?
Old Oct 1, 2004 | 06:29 PM
IllusionalTA's Avatar
get the regular kit and you'll be fine.. just be careful on them hard shift's.. it will crap a rear on a 3-4 shift!
LeftoverChinese
Jan 14, 2024 03:03 PM
Louey
Pacific
Dec 25, 2014 03:27 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
USAirman93
Nov 24, 2014 03:37 PM
jmzlt1
Mar 13, 2003 07:26 AM
