Rear Drum brake to Disc Brake conversion
Old Aug 12, 2004 | 08:58 PM
POSSESSEDZ's Avatar
what do i need to do this conversion and if anyone has done this can you give some detailed info on how you did it. thanks dave
This will be for a 1989 camaro rs.
Old Aug 12, 2004 | 11:17 PM
Jay-Roll's Avatar
Re: Rear Drum brake to Disc Brake conversion
I don't know from experience, but I'll try to help out. Obviously your going to have to get all the disk brake hardware compatible with your vehicle, probably improved brake lines(maybe not a must, but cheap insurance), and I'm sure a new master cylinder to be able to handle 4 wheel disks vs 2 drums/2 disks. I'm not sure if there's some type of swap done at the axle ends so you can swap em over though. Hope this helps out some. What vehicle is this for? There might be an entire kit out there to do this.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dale3in98
Feb 14, 2015 12:18 PM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
