rear dif. fluid change questions
Old Sep 3, 2003 | 08:42 PM
JS99Z's Avatar
I have a 99 Z with traction contol and abs with 3.23's. What kind of gear lube should I use in it? Synthetic? Do I need the limited slip additive? Is the limited slip additive compatible with the synthetic gear lube? What is the weight of the proper gear lube? Sorry about all the questions. I should probably read my manual huh?
Thanks to anyone that can help!
Woops probably should have posted this in the drivetrain section!
Old Sep 3, 2003 | 08:47 PM
chpmnsws6's Avatar
try to hold off on it and hurry and buy a T/A girdle! it makes it alot easier in the future because it has drain and fill plugs. i think its like 80/90w and yes you do need the limited slip additive (get it at the dealer but the oil you can get at the auto store). the gear lube and the limited slip additive are compatable of course
if you have anymore questions, my AIM SN is ramairstyle00. just say ur on here
Old Sep 3, 2003 | 08:50 PM
JS99Z's Avatar
Where can I get a T/A girdle at?
Old Sep 3, 2003 | 09:44 PM
chpmnsws6's Avatar
http://www.thunderracing.com/index.c...ategoryid=1066
its right in the center and its worth EVERY PENNY
Old Sep 3, 2003 | 10:01 PM
JS99Z's Avatar
F'n1996Z28SS
Aug 23, 2023 11:19 PM
PCLZ28
Dec 24, 2015 05:19 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
FredM
Dec 18, 2014 01:40 PM
Jul 4, 2005 05:00 PM
