Racheting sound now clutch pedal high
Old May 11, 2007 | 11:42 PM
Fuelman's Avatar
Exclamation Racheting sound now clutch pedal high
My boss pulled up on my clutch pedal and it made a racheting sound.
Now the clutch pedal is about an 1 1/2" above the brake pedal?
The car still shifts and drives ok but the pedal is to high up.
There is a switch above the pedal it's called the "clutch antisipation switch". Does this double as a stop? I'm sure the sound was from the plastic threads slipping through the jam nut.
Can I just depress the pedal, open the bleeder to purge the exess fluid and re-adjust the switch to it's original location?
Old May 30, 2007 | 06:12 PM
jaguareats's Avatar
theres a height adjustment under the dash. need to push petal down and push switch back down.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
themushine
Sep 3, 2002 10:02 AM
themushine
Sep 3, 2002 10:01 AM
