Quick question on gears
Old Jan 15, 2006 | 12:39 AM
GnarlyZ28's Avatar
Just wondering what kind of gears i have (2.73 or 3.23 i think). The engine's at 2000 rpms when im cruising at 60mph in overdrive (a4). Also, what would the rpms be at when cruising at 60 with 3.73s? 4.10s?
thanks
Old Jan 15, 2006 | 02:26 AM
blazzinbird's Avatar
Re: Quick question on gears
Here is what you need to do, open the driver side door, look for a tag that has alot of codes
GU2 Axle, Rear 2.73 Ratio
GU4 Axle, Rear 3.08 Ratio
GU5 Axle, Rear 3.23 Ratio
GU6 Axle, Rear 3.42 Ratio
find which code matches the odeon the door sticker
ChrisFrez
Feb 1, 2015 08:26 AM
ChrisFrez
Jan 25, 2015 08:06 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
